olivierporchy
syntax error IP 10G/25G Ethernet
Dear all
I have a syntax error in 10G/25G Ethernet when synthetizing.
The same IP synthetized in a Vivado 2020.1 design is OK.
Could you please give me assistance ?
Olivier
guozhenp
This error is fixed in 2021.2
guozhenp
Try generating the IP example design
Does the example have the same error?
olivierporchy
Sorry for the delay to answer, i was in hollydays.
The example design have the same error with Vivado 2021.1 (no error with Vivado 2020.1).
Olivier
guozhenp
Even the IP example design has the error?
Please provide the details, e.g. deveice family, IP configurations in every GUI page.
Or just upload the IP .xci file.
olivierporchy
Please find xci file attached.
Olivier
guozhenp
I check the attached .xci file. It doesn't look like IP core configurations.
Please let me know all the settings you've changed in the IP core GUI.
olivierporchy
Please try with the attached xci file
guozhenp
OK. I can see the error.
I created a new CR-1109486. It may take some time to fix it.
guozhenp
olivierporchy
Fine, thank you!
Olivier
