the SGMII link is low sometimes in vivado2019.1
HI,
i am using the SGMII ip and a hardware PHY (88E1111, marvell) to create a ethernet solution, the vivado is vivado 2019.1 and the FPGA is the V7 690T,
it works ok when i use the JTAG
to debug, but when i download the .bin file to the flash, and disconnect the JTAG, sometimes it cannot work , and the
status_vector[0], that is the link of the SGMII, is low, at this time , if i restart the device , or i put the reset button
to reset the whole device, it works ok ,the link of the SGMII, goes to high. so what is the problem ? i donot know what is
the key point.
thank you!
Re: the SGMII link is low sometimes in vivado2019.1
Hi @zhipengzhao ,
It looks like this issue is related to the way how you configure the board.
I would firstly check if the clocking is stable once the .bin is programmed into the flash. Thus a subsequent reset is needed to bring the link up.
HI nanz,
thank you!
i checked that the clock is stable , and i try to set the clock to 12Mhz or 9Mhz ,but it also happens .now i think it works  unnormal once in 10 times i test.
is there some suggestions for me? hope to get suggestions from you, thanks!
HI @zhipengzhao ,
What is this 12MHz and 9MHz clock? SGMII needs 125MHz clock.
Is a reset help to bring up the link once the SGMII link is down?
HI, nanz, thank you!
the 12MHz and 9MHz clock is the SPI clock for program. the 125MHz clock for SGMII is ok , because there are more than eight sgmii IP in my design ,they shared the 125M reference clock , and only one or two sgmii links down every time , at the same time others link up . a reset can not bring up the link once the SGMII link is down, so i am confused.
If the extra reset is always helpful, you can just create a protect logic in your design that do reset automatically after the timeout that the link is still down.
HI ,
