ammadali90
timing violation in Ethernet subsystem
I have a design which composes of 4 Ethernet subsystem MAC with RGMI interfaces. The Ethernet subsystem has GTX pin if I connect this pin to an external clock of 125 MHz in ZCU102 board the design works completly fine.
I don't want to use this external clock source for some reason, I want to drive the GTX pin from Zynq PS (external PL clock). But in that case I got setup timing violation.
Attached is the pdf of design and also the constraints suggested by AR#65947.
BR,
Ammad Ali
shanep1
@ammadali90 wrote:
I don't want to use this external clock source for some reason, I want usps tracking to drive the GTX pin from Zynq PS (external PL clock). But in that case I got setup timing violation.
BR,
Ammad Ali
Yeah need help with this too.
Thanks in advance.
Shane
________________________________________________________________________
guozhenp
What's the timing errors?
ammadali90
I have attached the Path report summary which has WNS.
BR,
Ammad Ali
ammadali90
I have attached the Path report summary!
Is it ok?
