sharon
translation_table cannot be found when generating the example design including cips
when generating mrmac example design, the log said translation_table cannot be found when generating the example design including cips on VCK190.But i can find the file on the installation path, cannot find on the corresponding path on  example design .
Tags (3)
sharon
Maybe the computer access changed, I changed the folder path from desktop to disk C  and run vivado with administrator, example design can generate successfully.
nanz
Hi @sharon ,
Could you please upload a screenshot of the example design together with the error message? In which step, did the log report this?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
sharon
nanz
Hi @sharon ,
Great to hear the issue is resolved. Could you please mark the relevant thread to accepted solution so it will also benefit other forum users? Thank you!
