mkaspare
transmitting frames source MAC address insertion
I use the following Core with the SP605 Dev. Board.
http://opencores.org/project,ethernet_tri_mode
In the main futures is written, that I can insert the source MAC address.
Does someone know how to do this?
Thanks in advance
yenigal
Check if you have a top level port to specify the source MAC address.
Also did yo try posting  your query at https://groups.google.com/forum/#!forum/opencores-tri-mode-eth-mac
Satish
mkaspare
unfortunately there is no such top port.
I have posted the same question few days earlier at the google group:
https://groups.google.com/forum/#!topic/opencores-tri-mode-eth-mac/fQxD96CR7-E
It seems to be dead...
Thank you
