I need ug1018,ug1016. Any help.
Re: ug1018
Please contact your local FAEs . These UG not available freely. You need to sign NDA with Xilinx to get these documents
Thanks and Regards
Balkrishan
Re: ug1018
Hi @mamin
These are internal. May I know where did you get these references from?
Thanks,Vijay
Re: ug1018
Thanks and Regards
Balkrishan
Re: ug1018
these are refrences from sdnet packet processing and not in xilinx website.if you are have these doc plese forward to me
Re: ug1018
@esfa yes these document related tp SDnet however only available for NDA customer . Please Xilinx FAEs to get access
Thanks and Regards
Balkrishan
Re: ug1018
I find references to these user guides from ug1012.
Re: ug1018
Hi my friend
I need sdnet to implement and simulation my poject.please everyone have knowledge about this and about how to run and use it hellp me.
i need emergency help.
