xikun.dai
v7 series support interface HDMI
hi ,
can we use V7 Series FPGA to directly interface HDMI in and HDMI out?
since some V7 FPGA have HR bank.
BR
Xikun
yenigal
If you want to use  HDMI to display the images, the output video signals from AXI4 Stream to Video Out  and input signals from  Video In to AXI4 Stream can be used.
Also refer below links which will give some suggestions on implementing the HDMI interface
http://www.xilinx.com/support/documentation/application_notes/xapp741-high-performance-video-AXI-interconnect.pdf
http://forums.xilinx.com/t5/7-Series-FPGAs/HDMI-transmission-with-Kintex-7/td-p/452984
http://www.xilinx.com/support/documentation/application_notes/xapp794-1080p60-camera.pdf
Satish
xikun.dai
thanks for your support.
in our design, we don't need to encode/decode HDMI , only want to forward the HDMI link layer packet to other bus.
i think the HR bank work as TMDS can receive HDMI input signal and decode it to HDMI link layer packet, right?
do you have any document to describe the interface between TMDS and Link layer packet?
BR
Xikun
