whta is clock speed in SRIO Interface on Virtex-7 FPGA
I am using Virtex-7 FPGA (xc7vx415tffg1157) and i want to conenct Two x1 GTH transceiver port from FPGA to  to SRIO switch. My SRIO speed should support upto 5Gbps. So, i need to connect  reference clock for SRIO interface. Can you please tell me the clock input range for FPGA GTH port.
Magalingam
Re: whta is clock speed in SRIO Interface on Virtex-7 FPGA
If you are using the SRIO core then reference clock of 125Mhz is needed to operate upto 5Gbps.
If using the wizard to support only the phy layer it supports various reference clocks which you can check using the
transceiver wizard.
Refer PG007 clocking section if using the core.
Satish
athish,
Thank you.
Magalingam
sathish,
Thank you.
Magalingam
Can you provide reference scheamatics for Virtex-7 FPGA with SRIO interface?
Magalingam
Also the following AR http://www.xilinx.com/support/answers/58402.html may give some more useful information for your requirement
Kintex7 and Virtex7 boards can be used for SRIO connectivity,Where the GT's can be used to Implement the SRIO functionality.
There are no specific Schematics for SRIO,You can check VC707 and VC709 schematics for reference.
Have a look at below post  where one of the possible connections is mentioned.
http://forums.xilinx.com/t5/7-Series-FPGAs/SRIO-multi-lane-connection-problem/td-p/412189
Satish
