Observer creator
why my zedboard not executing lwip echo server
when I my device(zedboard)  from my computer it shows that destination host unreachable???? please tell me the solution....
Re: why my zedboard not executing lwip echo server
Hi @creator
Are you monitoring the Lwip Echo server messages in the Serial Port (terminal), if so whether it got negotiated for the speed. Please attach the screen shot of the UART messages to this thread to check with.
Hi @creator
Observer creator
Hello.Thank you  for your response.
I dumped LWIP echo server program on zedboard.When I ping the zedboard from my computer it show like mentioned in screenshot.
My computer IP:192.168.1.12
My zedboard IP :192.168.1.10
what is port 7???
Observer creator
please reply sir..
HI @creator
Can you please share with me the UART debug print screen shot to check with. It also depends on the settings you have done at PC. I believe you have set a static IP at the PC. Can you also check for the negotiated speed at the PC and even in the UART debug statements of Zed board (please share the screen).
As per your question on what is Port, as you are running a Server at Zed board it will have a port address  when you want to connect it with a client. we can discuss on this further once you get the Ping working.
Observer creator
what is UART debug print screen??
Observer creator
Hello sir.Actually fisrt I connected the block diagram using zynq block,AXI interconnet,AXI GPIO blocks.
Then I generate the bitstream and export it to hardware,Lanuch SDK
Then I create LWIP echo server project,
I connect the zedboard to my pc and I connnect  my pc LAN to My zedboard ethernet port.
When I power on zedboard the LED at ethernet port start blinking in yellow color.
I program the FPGA then blue light is blinked on zedboard.
From Internet I knew that first we have to check whether our pc connect with zedboard or not ?
So I ping the zedboard with assigned IP but my pc shows destination host unreachable.
In my pc adapter seetings
Ip:192.168.1.12
subnet mask:255.255.255.0
gateway:192.168.1.0
DNS server:10.1.3.5
alternate DNS server:10.1.3.6
Hi @creator
Can you try with gateway changing to 192.168.1.1 and clearing the DSN server fields.
Observer creator
Thank you for your reply sir.I did the same what you told .
I successfully executed the lwip echo server. when I ping my computer It replies how many packets send and receive.
Now I want to transfer some data to zedboard like a file or video etc. and I want to see the reply from zedboard.
please tell me how to see the output and tell which software to use output data.
Hi @creator
Please try to follow XAPP1026 for the File Transfers (TFTP).
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
It has below applications
you can go through the reference design downloaded.
Observer creator
Thankyou
Observer creator
Hello.
If I want to send data to zed board shall I need to boot the zedboard with linux os or any other os.
please clarify my doubt..
Visitor belqassim_84
did you Check the MAC@ (should be the same as your board's) used in your program?
MAC or physical @
Hi @creator
That may be your choice to use baremetal application from XAPP1026 or you can boot linux if you are comfortable doing so.
Observer creator
can't we do it by using windows 10???
Observer creator
we are getting an error while generating bitstraem of ethernet fmc by using echo server,can u suggest me how to overcome it?we are attaching screenshot of error????
Hi @creator
Can you please create a new thread in Networking and Connectivity Board for the hardware connectivity and if you are facing issues with the linux porting on zedboard you can create a post in the  Embedded Linux Board. Thanks for your understanding on this.
Observer creator
Sir please tell me that why we need os on zedboard .can we do with out os???
Hi @creator
You can do the File transfer using TFTP application as provide in XAPP1026 with out linux. I am suggesting for the post can be further discussed if you need any hardware related issues (FMC attached PHY) in a right board i.e., Networking and Interface  so that other may get visibility of the post.
Observer creator
Ok.Thankyou for your explanation.
Now my new doubt is how to do file transfer with TFTP protocol??
Can you please give any Idea how to proceed?
