xapp1305 (Pl_eth_sgmii) in vivado 2017.3
Hi all,
Does anyone face problem of using xapp1305 (Pl_eth_sgmii) in vivado 2017.3 (By IP updating). I am using LWIP in SDK. With that I was not able to ping from my local machine. The terminal stuck at "TCP packets sent to port 6001 will be echoed back" and then nothing happened!
I tried xapp1305 (vivado 2017.1), and Pl_eth_sgmii works completly fine.
Do you have any idea about the problem?
I am using ZCU102 board.
Best Regards,
Ali
Hi @ammadali90 ,
I've also sent you 2017.3 design through emails. Please try that out and let me know if you did not get it.
Hi @ammadali90 ,
Are you using the ready-to-download images from 2017.3 or you are building your LWIP application in SDK to test? Please could you try both and see how it works? There is a FSBL clock patch which should be used in 2017.3 SDK.
Yes, I am using LWIP application in SDK to test. Do I also need the clock patch to generate my own application in SDK?
Hi @ammadali90 ,
Yes, please try to apply the FSBL patch and test it again.
Also, I'd be interested in seeing you try the ready-to-download images, assuming you are using ZCU102.
I dont find ready to download image for 2017.3. I used the TCL script of xapp1305 from 2017.1. By updating the IP versions in TCL script I used it on 2017.3. Thats how I build the xapp1305 design.
@nanzCould you please tell me that how I apply the patch in SDK?
Hi @ammadali90 ,
You should be able to add the patch directly in SDK and refresh the dirctory to see if it's done.
Hi @ammadali90 ,
Hi @nanz ,
I run the pl_eth_sgmii script in 2017.3 and nothing happened. Have same problem.
I also applied the patch in SDK, make no difference.
Hi @ammadali90 ,
What do you mena nothing happend? have you triedready-to-download images?
Yes, I tried and it works!
Thanks!
