xapp1305 (Pl_eth_sgmii) in vivado 2017.3
Hi all,
Does anyone face problem of using xapp1305 (Pl_eth_sgmii) in vivado 2017.3 (By IP updating). I am using LWIP in SDK. With that I was not able to ping from my local machine. The terminal stuck at "TCP packets sent to port 6001 will be echoed back" and then nothing happened!
I tried xapp1305 (vivado 2017.1), and Pl_eth_sgmii works completly fine.
Do you have any idea about the problem?
I am using ZCU102 board.
Best Regards,
Ali
Hi @ammadali90 ,
I've also sent you 2017.3 design through emails. Please try that out and let me know if you did not get it.
"Don't forget to reply, kudo and accept as solution."
Hi @ammadali90 ,
Are you using the ready-to-download images from 2017.3 or you are building your LWIP application in SDK to test? Please could you try both and see how it works? There is a FSBL clock patch which should be used in 2017.3 SDK.
Yes, I am using LWIP application in SDK to test. Do I also need the clock patch to generate my own application in SDK?
Hi @ammadali90 ,
Yes, please try to apply the FSBL patch and test it again.
Also, I'd be interested in seeing you try the ready-to-download images, assuming you are using ZCU102.
I dont find ready to download image for 2017.3. I used the TCL script of xapp1305 from 2017.1. By updating the IP versions in TCL script I used it on 2017.3. Thats how I build the xapp1305 design.
@nanzCould you please tell me that how I apply the patch in SDK?
Hi @ammadali90 ,
You should be able to add the patch directly in SDK and refresh the dirctory to see if it's done.
Hi @ammadali90 ,
Hi @nanz ,
I run the pl_eth_sgmii script in 2017.3 and nothing happened. Have same problem.
I also applied the patch in SDK, make no difference.
Hi @ammadali90 ,
What do you mena nothing happend? have you triedready-to-download images?
Yes, I tried and it works!
Thanks!
