xapp1306 - waiting for PHY to complete autonegotiation
Hello all,
how are you? I am trying to make xapp1306 work to try and test the 1G PL Ethernet, however I am having some troubles.
To start with, I was not able to create a good boot image. I have three file groups:
1- fsbl
2- iperf_a53
3- pl_eth_1g_wrapper_hw_platform
In the first moment I put the fsbl.elf as a bootloader, the iperf_a53.elf as a data file (all in the a53 core), and finally the bitstream. As it didn't work, I tried different combinations (fsbl+iperf), (fsbl+bitstream), (iperf+bitstream). Non of these worked. So what I did was to Program the FPGA with the bitstream and launch the iPerf application, and I was able to see this:
However, it is freezed and it nevers finish the autonegotiation.
I don't know which is the problem, neither if the way I program it is the best.
Could you please help me?
Thanks and best regards,
baldrism
Hello all,
I tried again to upload the binary files into the ZCU102 and all the time (with my images and with the ready_to_test images), there is a RED led in my FPGA that turns on, and I cannot see any output from the A53 CPU.
See the screenshot:
My FPGA is the ZCU102 Rev 1.1. It is possible that this example only works for revision 1.0?
I would appreciate your opinions about this.
baldrism
Any help???
baldrism
