zynq7 rgmii via mio
Hi,I put a ethernet phy(BCM54616SCOIFBG)on ps_mio,the two ports are connected with RGMII interfaca(HSTL_18),the mio bank is powered by 1.8V,and the ps_mio_vref_501 is powered by half vcc_mio.The tx data/ctrl/clk and rx clk is termanited to half vcc_mio.
The trace length between two ports is about 3700mil,and the skew between all the traces is less than 10mil.
We read the status of the phy from MDC/MDIO.It seems that the chip is working well, and the link-up is shown on the screen,but we can't ping the target ip, package loss 100%.
We used to put this phy on the PL,the HP_DCI port,still HSTL_18,everything is OK,but there is no DCI on ps_mio.
The phenomenon is so weired,is there any SI problem?  According to the ZC706,there is no termination on the rgmii,what should I do? Cut all the terminations on the TX?  or put termination on the RX at fpga side ,just like DCI?
Re: zynq7 rgmii via mio
Please refer to Xilinx Eval board schematics and board.
Seems that MDC/MDIO working and link is up, i believe issue might not be related from board.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Pratap
you mean  it's software configuration that cause this problem?
