AC701, ADV7511 and I2C
I've been trying to read back a configuration from an ADV7511 on an AC701 dev board.
So far, no success.
I used the code from xapp741 (for a kintex dev board). I used the XIic_DynSend / XIic_DynRecv functions from the code but it does not work for the ADV7511.
It works for the I2C switch though...
Do anyone has a working function to read & write a byte to an ADV7511? This device is driving me crazy.
Moreover, is there a documentation describing the I2C API for the Xilinx I2C PL IPs?
Many thanks.
--Sebastien
Re: AC701, ADV7511 and I2C
Hi @sebo,
Why do you want to read the configuration from the ADV7511?
If this is only to use the ADV7511, I wrote the Video Series 19 and Video Series 20 to show how to use it on the ZC702 but this can be applied on the AC701.
Note that I am doing write for the configuration and read to get the status of the HPD.
Florent
Hi @florentw,
Thanks for answering. Yes we plan to use your video series posts. but, you code is for the I2C PS. The API differs from a I2C PL... I don't know why.
So we can't use as is the code you provided. Therefore, the R/W I2C functions must be adapted.
--Sebastien
HI @sebo,
I remember porting the xapp741 to tha AC701 board, but I cannot remember if I faced doing it. From what I remember it was pretty straight forward (change vivado design to match changes in ADV7511 connections and change the configuration of the ADV7511).
I think I used XIic_Send (not dynamic). The small catch I can think of is that I needed to wait for the i2c bus to be free before reading/writing anything.
Florent
