Visitor chao_xilinx
About LCD display in kc705
I was trying to write some verilog code to drive the LCD display.
However, I realized that our data[3:0] is not connected. For the examples I studied, they all have [7:0] data bus for each character.
How can I work out this? Do you have some working sample code for kc705 FPGA?
Thanks!
Re: About LCD display in kc705
If you search online for "16x2 LCD HDL", you'll find example code.
I found one on Opencores written in VHDL that is well documented and this subset written in Verilog:
https://www.quora.com/What-is-the-Verilog-code-to-display-a-character-on-an-LCD-screen-of-the-Spartan-3E-XC3S400-FPGA-kit
KC705 has a 7 pin interface to it. From the XDC file:
 Line 812: set_property PACKAGE_PIN Y11 [get_ports LCD_RS_LS]
 Line 813: set_property IOSTANDARD LVCMOS15 [get_ports LCD_RS_LS]
 Line 814: set_property PACKAGE_PIN Y10 [get_ports LCD_DB7_LS]
 Line 815: set_property IOSTANDARD LVCMOS15 [get_ports LCD_DB7_LS]
 Line 816: set_property PACKAGE_PIN AA11 [get_ports LCD_DB6_LS]
 Line 817: set_property IOSTANDARD LVCMOS15 [get_ports LCD_DB6_LS]
 Line 818: set_property PACKAGE_PIN AA10 [get_ports LCD_DB5_LS]
 Line 819: set_property IOSTANDARD LVCMOS15 [get_ports LCD_DB5_LS]
 Line 820: set_property PACKAGE_PIN AA13 [get_ports LCD_DB4_LS]
 Line 821: set_property IOSTANDARD LVCMOS15 [get_ports LCD_DB4_LS]
 Line 822: set_property PACKAGE_PIN AB13 [get_ports LCD_RW_LS]
 Line 823: set_property IOSTANDARD LVCMOS15 [get_ports LCD_RW_LS]
 Line 824: set_property PACKAGE_PIN AB10 [get_ports LCD_E_LS]
 Line 825: set_property IOSTANDARD LVCMOS15 [get_ports LCD_E_LS]
Andres
Andres
