Anvyl Spartan-6 FPGA Trainer Board Ethernet connection
I will brief how I proceeded with the project and what problems I faced? I am using Anvyl Demo for Ethernet for this project.
I started with Run DRCs in EDK and then to Generate Netlist.  After obtaining XST Completed with no errors with a few warnings, I proceeded to Generate Bitstream. After completing the Generate Bitstream with no errors, I proceeded to Export Design & Launch SDK. I regenerated the whole BSP and project. The elf is well generated and I added the generated elf file to Imp Executable of Microblaze in EDK (XPS).
 Then, I Update Bitstream so that elf and bit files are linked and Download Bitstream to the FPGA. I configured the IPV4 settings on my laptop to the following as per the Anvyl_demo_doc.pdf. As per main.c, IP address of the FPGA is 192.168.1.10.
Opening XMD and executing ping 192.168.1.10, I got like below.
I also tried the other way also. Download Bitstream without attaching an elf file and then Program FPGA after building the project in SDK. But the result remains same.
I expect a reply from 192.168.1.10 if the project is compiled or the configuration is in the correct way. Please help me in finding where I made a trouble and how to rectify it.
Thanks in advance.
