Visitor ayooshb2
Boards similar to ZCU102
I am looking for a development board similar to ZCU102 but with more AXI masters from PS to PL. ZCU102 has 3 total (AXI HPM0/1 FPD, AXI HPM0 LPD) which is not sufficient for my purpose.
Any pointers are appreciated.
Thanks!
Scholar u4223374
Re: Boards similar to ZCU102
I think you'll be waiting about ten years for that. It will have to wait until the next generation of Xilinx chips, as the Zynq UltraScale+ has the configuration you described across all devices.
However, this should not be a problem. Just stick an AXI Interconnect in the PL, set it to one slave port (which connects to your AXI Master from the PS) and as many Master ports as you want.
Scholar u4223374
Visitor ayooshb2
Thanks! I did not realize that all current chips have this limitation. You are right, functionally this is not a problem. But AXI buses seem to be the bottleneck when multiple high perf cores access PL DRAM.
