Can we get the license for ZCU111 board before we receive the board?
Hi everyone,
We purchased ZCU111 board from Xilinx. The order was placed a few weeks ago and we haven't received the board yet.
I just found that we need license in Vivado 2018.2 to support device "xczu28dr", so that I can build some projects for this board.
From the Xilinx website I found that the ZCU111 board comes with a node-locked license for this device. Is it possible to get the license before we get the board?
Thank you.
Tong
Re: Can we get the license for ZCU111 board before we receive the board?
Hello @onlinext
If you have full license of your VIVADO then you should automatically have access to all the RFSoC devices.
can you please check if you selected all the parts under device section while installing the tool ?
It's true that ZCU111 board files are not present for VIVADO 2018.2 but RFSoC devices are still accessible if you have complete VIVADO license.
You can check this from help-> Add design tools and devices section in your installed vivado.
Hope this helps.
Scholar u4223374
@onlinext I'm pretty sure you can get a 30-day Vivado Evaluation license which allows access to all chips except for the engineering sample ones. Might be worth giving that a try.
Hi @u4223374,
Thanks for your reply.
We already have valid license for Vivado 2018.2. The problem is that we lack the license for ZCU11, whose part number is XCZU28DR.
An evaluation license for this device will be good. Could you tell me how to get it?
Thank you.
Tong
Scholar u4223374
@onlinext If your 2018.2 license isn't device-locked, then you just need to install the 2018.2.1 update (which adds support for the XCZU28DR).
If it is device-locked (eg. included with another development board) then an evaluation license is required. It's been a while since I did this, but I think that you just login to your account, head to the licensing section, and then you can generate the license.
Hi @u4223374,
Thank you very much.
I'll try it.
Tong
Hello @onlinext
Hope this helps.
Hi @kvasantr,
I just confirmed with the IT department that we don't have valid license for Vivado 2018.2. I thought Vivado 2018.2 shares the same license as Vivado 2015.4, but actually they don't.
Tong
