Capturing ADC data with KC705 Evaluation Board
hi
I am using ADS5294EVM which is a 8 channel ADC
the output from ADC is LVDS
i have a FMC-ADC-ADAPTER which is used to interface
ADC to KC705 board.
i need to tranfer the ADC data to DDR3 meomry
in KC705 board.
the HR bank of FPGA which is connected FMC connector
has VCCO votage VADJ_FPGA = 2.5 V set as default
how do i capture the data from ADC to KC705 DDR3 memory?
which IOSTANDARD must be used to constraint file
for input to FPGA from ADC?
 Thanks and Regards
Gaonkar
Re: Capturing ADC data with KC705 Evaluation Board
Hi Gaonkar,
KC705 has 2 FMC connectors: J2 which is LPC and J22 which is HPC. Both of them have several pins set up as LVDS to communicate with your ADC.
Please take a look at UG810, pg 63-70:
https://www.xilinx.com/support/documentation/boards_and_kits/kc705/ug810_KC705_Eval_Bd.pdf
Andres
