Visitor arjun_nadh
DS1 LED in ZCU102 is red
I have been using a ZCU102 board with AD9371 FMC card for sometime now. Everything was fine.
All of a sudden the DS1 LED started becoming red, and then I cannot program the FPGA. Initially the red colour disappeared after switching on
the board after a long time, but now whenever I switch on, DS1 is red. Please help me with this.
IMG_20181222_184957-min.jpgDS1 LED red in color
Re: DS1 LED in ZCU102 is red
Hi @arjun_nadh,
Please go through this ZCU102 Debug Checklist, and confirm me till Step4 there are no issues? If the board is getting detected through Vivado hardware manager please share the snapshot.
1. Please share Vivado version and OS details?
2. Which configuration mode you are using to configure the FPGA?
     ---If you are facing issues in configuring the FPGA through JTAG or QSPI mode, please refer STEP 5 and 6 in ZCU102 Debug Checklist.
3. Please perform Flash Restoration, by referring Flash Restoration tutorial and refer Restoration Files. After Performing Flash restoration please share the Power Good LEDS snapshot.
4.After Step3, Try to configure the FPGA from configuration modes listed in UG1182 (v1.4).
can you please check with Analog devices, whether AD9371 has been tested/supported in rev1.1 board?
let me know if this helps.
Deepak D N
Please Reply or Give Kudo or Mark it as an Accepted Solution.
Hi @arjun_nadh,
Deepak D N
Visitor arjun_nadh
Hi Deepak,
Thanks for the reply. I am going through the debug checklist. In step 1 when I was checking the Jumpers, I found that for J162 and J88
was left open, which is different from the default configuration listed.
For step 2 to check power I don't properly understand how to check for the voltages. Should I use a multimeter and if so which pin should I
check for?
Thanks and Regards
Arjun Nadh
Visitor arjun_nadh
Hi, Forgot to mention, my vivado version is 2018.2
Arjun Nadh
Hi Arjun,
Please take a look at these ARs:
https://www.xilinx.com/support/answers/66882.html
https://www.xilinx.com/support/answers/66811.html
If you can get a Maxim cable, it's worth checking that.
Andres
Visitor arjun_nadh
Thanks for the response. We tried both the links but it did not resolve the problem. We have now talked to the Xilinx support and they raised a service request for the same.
Arjun
