Difference between different versions of ZC706
I have two ZC706, the versions of these two board are different.
I can run 'zc706_ibert' demo successfully on the older one, while the same demo run failed on the newer one.
How many version? does ZC706 has?
How to confirm the version of ZC706?
Re: Difference between different versions of ZC706
Hello @mage,
Can you please elaborate more ?
which version of example design you used with which version of board ?
also which combination failed ?
ZC706 has following number of versions:
Thank you.
The 'rdf0241-zc706-ibert-c-2015-4.zip' demo run failed on ZC706 version 2.0.
I have made a mistake. Both two ZC706 are version 2.0. So may be I could confirm that there is some problem with the ZC706.
Hello @mage,
try debugging board as per AR#54013
Share the results with us.
Thank you.
I have debug the board following AR#54013. The IBERT still run failed
