Difference between the ZCU102 and ZCU102-ES eval. kit
Hi, can anyone tell me how to see the ZCU102 Eval kit I just bought is using the XCZU9EG-FFVB1156-2I or  XCZU9EG-FFVB1156-2I-ES2 chip? It is not specified in the Quick Start Guide that comes with it.
I need to know if I am using the correct board files for Vivado. Currently I am using only the XCZU9EG-FFVB1156-2I
Finally what is the differences between the ZCU102 and the ZCU102 ES?
Thanx
Re: Difference between the ZCU102 and ZCU102-ES eval. kit
Also refer https://www.xilinx.com/support/answers/66752.html to know main differences between  ZCU102 and ZCU102-ES eval. kit.
Probably ZCU102 Eval kit might be the final production part.
Quickest way is to connect JTAG and look at the ID.
The first (hex) digit is the version:
0=ES1
1=ES2
2+ = production
https://www.xilinx.com/support/answers/37579.html
Observer swdave
