Visitor tmbcoder
Examples about Tri Mode Ethernet Mac IP core for Zedboard
Hi everyone,
i have bought a zedboard board, i run my application based  lwIP in it and it run well .
In my PC, i write C-socket program to transfer .bin file but when the data that i transfer is big, it run slowly .
Is Tri Mode Ethernet Mac IP core  can help me to solve that problem ? I want my PC send data directly to Programable Logic (FPGA) through IP address and port and i think it will improve the performance of my system.
With TEMAC core , i can't look any example for Zedboard.
With zedboard , i know that we must change ethernet from MIo 16..27 to EMIO following the link http://zedboard.org/content/redirecting-peripherals-mio-emio
Can you help me ? Thanks very much.
Tags (3)
Scholar hbucher
Re: Examples about Tri Mode Ethernet Mac IP core for Zedboard
@tmbcoder
Look at xapp1305 - PS and PL-Based 1G/10G Ethernet Solution
https://www.xilinx.com/support/documentation/application_notes/xapp1305-ps-pl-based-ethernet-solution.pdf
One small change that can make a big difference is to handle packets with polling instead of interrupts.
XAPP1306 is based on LWIP; But both xapp1305 and xapp1306 are for ZU+ devices.
For Zynq, you can refer to XAPP1082 (though this is for Linux).
http://www.wiki.xilinx.com/PS+and+PL+based+Ethernet+in+Zynq+MPSoC.
https://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf
Visitor tmbcoder
Dear,
Thank for your help, but when i try to run examples , the errors is vivado 2017.1 doesn't have xczu9eg-ffvb1156-2L-e-es1 part in it ?
How can I fix it ? Thank you!
Scholar hbucher
@tmbcoder
You have to enable "Engineering Samples" on the install
In the project screen you have to enable "All Versions"
And make sure your ES1 license it is not expired.
https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/Synthesis-Failure-for-ZCU102-Vivado-2016-1/td-p/699729
