Visitor ccarrot
FMC XM105 Debug Card and VC707 connection problem.
Hi All,
I got  a new FMC XM105 Debug Card yesterday, however, I am facing diffulty when I plug it into my VC707 evaluation board.
The VC707 board runs well before, I can correctly dump codes into it and run it. But when I just put the XM105 card onto the FMC HPC connector, no matter which one is, the Hardware Manager always gives error, showing:
[Labtools 27-2269] No devices detected on target localhost/xilinx_tcf/Digilent/21020381213A.
Check cable connectivity and that the target board is powered up then use the disconnect_hw_server and connect_hw_server to re-register this hardware target.
If I take the XM105 card out, everything goes back (the Hardware Manager can connect the VC707 and dump bitstream onto it).
Can anybody tell what is the possible problem? Thank you very much!
Scholar pratham
Re: FMC XM105 Debug Card and VC707 connection problem.
@ccarrot This should work
http://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/VC707-FMC-incompatible-with-XM105-Debug-Card/td-p/251778
-Pratham
Scholar pratham
-Pratham
The FMC XM105 Debug Card is designed to provide access to many of the pins on the FMC connector found on Xilinx FMC-supported boards including the SP601, SP605 and ML605. I do not think XM105 base board support is there for VC707 board. Please refer http://www.xilinx.com/products/boards-and-kits/fmc-cards.html  for more information regarding base board support information
Also once try to debug as per section-4 (JTAG Initialization) and Section-5 (JTAG Configuration) in http://www.xilinx.com/support/answers/51233.html and see any change.
Visitor ccarrot
Hi Pratham:
Thank you for your information. I jumpered TDI and TDO on the xm105 board, and it now works! Thank you!
Visitor ccarrot
Hi umamahe:
According to your mentioned link, the XM105 supports:
AC701, KC705, VC707, VC709 ZC702, ZC706, ML605, SP601, SP605
Even though it is showing only SP601, SP605 and ML605 on the user-manual. The problem happens on the TDI and TDO connection for the FMC.  Just jumper the TDI and TDO pins on connector J5 of the XM105, gives a JTAG-chain path from the PC to the FPGA chip, then the Hardware Manager can find the device and program it. Thank you for your concern, now it works fine for me.
Thank you!
