FMC connection for ZC702 Evaluation Kit and ZC706 Evaluation Kit
Hi All,
         For my project , I am using Xilinx Zynq-7000 All Programmable SoC ZC702 Evaluation Kit. In it I have made FMC daughter board PCB which can fit into FMC #1-LPC connector and FMC #2-LPC connector.
       Now we want to shift our project for Xilinx Zynq-7000 All Programmable SoC ZC706 Evaluation Kit . So I want to know that FMC daughter board PCB which I have made for Soc ZC702,  can fit into SoC ZC706's FMC connectors?
Thank You.
------Vishal
Re: FMC connection for ZC702 Evaluation Kit and ZC706 Evaluation Kit
Please check FMC page on Xilinx website:
http://www.xilinx.com/products/boards_kits/fmc.htm
and ZC702 kits webpage for further information and available docs:
http://www.xilinx.com/products/boards-and-kits/ek-z7-zc702-g.html#documentation
Observer raseshjd
I think you can use the same FMC connector of ZC702 for ZC706 Kit.
LPC Connectors of both kits are same while for HPC Connector of ZC706 only uses limited pins (Which are same as  LPC Connector: H,G,D,C Pins).
Please refer schematic of ZC706 for more information from below link.
http://www.xilinx.com/products/boards-and-kits/ek-z7-zc706-g.html#documentation
Tags (3)
