Visitor alireza11045
How can i ssh to zc706 board
Hi to all,
i am beginner in zc706 devboard, i followed steps described in https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841655/Prepare+Boot+Medium and then downloaded prebuild image from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842365/Zynq+2017.2+Release and copied all files that exist in 2017.2-zc706-release.tar.xz in boot partition of sd-card and then attached sd card to the zc706 board. and then connect the board to the local lan network. but after power on i could no find the device in the network.
how can i make sure that os botted correctly?? can i connect board to the monitor with HDMI cable??
there is any further step is required to make ssh connection to zc706 board??
thanks
Re: How can i ssh to zc706 board
The Wiki is amazing. That being said we have a whole document describing getting started that might better suit your needs. This will walk you through the basics of board Configuration and using the design. It even has some debug steps. It has various visual interfaces to, that will show the design working.
https://www.xilinx.com/support/documentation/boards_and_kits/zc706/2014_4/ug961-zc706-GSG.pdf
