Visitor kingkong_529
Is there some ZC706 qspi flash example program,example test step which is succeed?
I have problem when test ZC706 qspi flash refer to "http://www.wiki.xilinx.com/Zynq+QSPI+Driver".
I have config the kernel refer to "Xilinx QSPI Driver Kernel Configuration"
I have config the device tree refer to "Devicetree Settings", and I change the string from "compatible = "n25q128""
to "compatible = "n25q128a11"".
And then,I can find the partitions with the command "cat /proc/mtd":
dev: size erasesize name
mtd0: 00e00000 00020000 "qspi-fsbl-uboot"
mtd1: 00500000 00020000 "qspi-linux"
mtd2: 00020000 00020000 "qspi-device-tree"
mtd3: 00ce0000 00020000 "qspi-rootfs"
mtd4: 00000000 00000000 "qspi-bitstream"
the linux boot log is follow:
m25p80 spi0.0: found s25fl128s, expected n25q128a11
m25p80 spi0.0: s25fl128s (32768 Kbytes)
5 ofpart partitions found on MTD device spi0.0
Creating 5 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000c00000 : "qspi-rootfs"
0x000000c00000-0x000001000000 : "qspi-bitstream"
Then:
# flashcp -v ./sample.bin /dev/mtd3
Erasing block: 1/32 (3%) random: nonblocking pool is initialized
Erasing block: 32/32 (100%)
Writing kb: 4096/4096 (100%)
Verifying kb: 0/4096 (0%) flashcp: verification mismatch at 0x0
It is Verifying failed。
There is two problem:
1.the rang of the adress show in "cat /proc/mtd" are not the same with the devicetree and the boot log.
2.flashcp verifying failed.
Is there something wrong with my step ?and Is there example program and example test step which is succeed on
ZC706 ?
Re: Is there some ZC706 qspi flash example program,example test step which is succeed?
you can find example design here
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0040-zc706-evaluation-kit-hub.html
Thanks and Regards
Balkrishan
