Observer seemasimon
KC705 Evaluation Kit - J22 FMC connector standoff part missing in BOM
On the KC705 board FMC connector J22 has 2 standoffs I do not see them on the BOM <https://www.xilinx.com/support/documentation/boards_and_kits/kc705_Schematic_xtp132_rev1_1.pdf>  can you find out what is used for the standoff?
Re: KC705 Evaluation Kit - J22 FMC connector standoff part missing in BOM
Are you referring to the two holes on either side of the FMC connector? The plated through holes? It is part of the FMC vita spec.
Community Manager
Community Manager
@seemasimon I believe you are referring to what standoff's to use to fix the FMC daughter card in place when connected to J22.
If so, the standoff's generally are part of the FMC daughter Card BOM and not KC705.
For example, XM105 Debug card, ships with below screw and standoff's per  XM105 BOM
These standoff's can be used for FMC daughter cards to mount onto KC705 in your case.
- Giri
Observer seemasimon
@gnarahar  thanks for the reply, see the attachment. The white standoff is what I need the information on.
Community Manager
Community Manager
@seemasimon Ok. Did you get it with KC705? It looks similar to MSO1,MSO2 Standoff mentioned in KC705 BOM/Schematic. Part#8400 from keystone
It is used for mounting FMC card in place when cables are mounted on the FMC card from one board to another and to prevent the FMC card from getting disconnected from the LPC/HPC connector due to cable weight or tension.
- Giri
