Kintex Ultrascale Board Availability at Vivado 2014.4
How to get Kintex Ultrascale Boards (KCU105) at Vivado 2014.4's Default Part-->Boards Section option. In my Vivado 2014.4 there is no any Ultrascale Boards.
krishna@logictronix.com
Scholar pratham
Re: Kintex Ultrascale Board Availability at Vivado 2014.4
@krishnagaihre Website is down here. I have board.xml file for 2014.4.1. PFA
-Pratham
Scholar pratham
@krishnagaihre  Cant you download 2015.1? here are the steps to get this in 2014.4.1
1) Download the PCIE-tutorial pdf and attachment (rdf0316 kcu 105), you will see the board_part.xml
Please check the snapshot
2) Extract the board_part.xml file to this location: C:\Xilinx\Vivado\2014.4\data\boards\board_parts\kintexu\kcu105\1.0
3)  create a new project and select the board part KCU105
P.S The board.xml in 2015.1 has all the interfaces compared to 2014.4 xml file so i would recommend you to please download the latest vivado to use the latest board file
-Pratham
Hi @krishnagaihre,
Kintex Ultrascale Evaluation board has been added from Vivado 2015.1 release So as suggested by @pratham You need to download Vivado 2015.1 to use KUC105 board.
http://www.xilinx.com/support/download.html
Syed
Thank You for Suggesting solutions, I am downloading 2015.1 , and also tried on 2014.4 now. Thanks again!
Scholar pratham
@krishnagaihre Please close this thread by makring it as a solution
-Pratham
@pratham , Can you please provide me the file : RDF0316 - KCU105 PCIe Design Files (2014.4.1 ES3) zip file, from which you gave the snapshots.I am not able to get the file for 2014.4.1, rather i get for 2015.1.  I need it cause 2015.1 seems to take time for download.  Thanks!
Scholar pratham
@krishnagaihre https://secure.xilinx.com/webreg/login.do?oamProtectedResource=wh%3Dwww.xilinx.com%20wu%3D%2Fwebreg%2Fclickthrough.do%3Fcid%3D385062%26license%3DRefDesLicense%26filename%3Dxtp350-kcu105-pcie-es3-2014-4-1.pdf%26languageID%3D1%20wo%3D1%20rh%3Dhttps%3A%...
 Please note you need 2014.4.1 not the 2014.4. Why dont you download either 2015.1?
-Pratham
Use the following link:
http://xgoogle.xilinx.com/search?output=xml_no_dtd&ie=UTF-8&oe=UTF-8&client=support&proxystylesheet=support&site=Answers_Docs_Forums&filter=0&num=200&sort=date:D:L:d1&getfields=*&show_dynamic_navigation=1&requiredfields=-Archived%3Atrue&q=xtp350&as_q...
Click on .zip file to download.
--Syed
@syedz can you please provide me the working link. the link you provide is not working , shows : An unknown error occurred.
Scholar pratham
The link given by @syedz is 2015.1. did you try link given by me for 2014.4.1? What do you want 2014.4.1 or 2015.1?
2015.1 board file will not work in 2014.4.1
-Pratham
Hi @krishnagaihre,
@pratham is right. I have sent you files for 2015.1 which will not work for 2014.4
I suggest you to download Vivado 2015.1 from Xilinx website.
--Syed
Scholar pratham
-Pratham
@krishnagaihre,
i am also getting the same error for any search on support page. Seems like the website is down.
Syed
@pratham,Thanks for the boards_parts.xml, if you can please provide me the RDF0316 - KCU105 PCIe Design Files (2014.4.1 ES3) zip file all the attachment which consists of the file you uploaded to me.
@pratham, @syedz, Thanks again!
Scholar pratham
@krishnagaihre PFA
-Pratham
Thanks Again!
