Visitor ruizmartinez
ML507 evaluation board problem with MIG DDR2 controller
I need help in order to know how tos olve this problem:
ERROR: Route:537 - A core generated by the Memory Interface Generator
(MIG) has been detected in this design but PAR is unable to route the
critical signals of this core to meet the necessary skew and delay
requirements. Please ensure that there are no location constraints or
Directed Routing constraints on the MIG core logic/routes that could
conflict with automatic placement and routing. To generate an NCD that
can be used for debugging in FPGA Editor, please re-run PAR with the
environment variable XIL_PAR_DISABLE_MIG_ANALYSIS 1. Note that if this
NCD is used, the design can fail in hardware. Below is the list of nets
in which PAR had problems routing optimally:
Sig:
u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[0].u_iob_dq/stg1_o
ut_rise_sg3
Sig:
u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[1].u_iob_dq/stg1_o
ut_rise_sg3
Thank you very much.......
emilio
Re: ML507 evaluation board problem with MIG DDR2 controller
We need some more information to help solve your problem.  How did you create the design for the ML507?  How did you get the UCF for the design?
Thank you for your answer... I give you more information .......
I create the design with MIG 3.2, target device xc5vfx70t speed grade-1 present in the ML507 evaluation board ...... I've created my own application and I instanciate teh mem_controller module.........
I copy the UCF file from MIG directory and I add my new signals .... This is the UCF;
##  Xilinx, Inc. 2006            www.xilinx.com
##  Thu Nov 19 11:14:21 2009
##  Generated by MIG Version 3.2
##  File name :       ddr2_mem.ucf
##  Details :     Constraints file
##                    FPGA family:       virtex5
##                    FPGA:              xc5vfx70t-ff1136
##                    Speedgrade:        -1
##                    Design Entry:      VHDL
##                    Frequency:         200 MHz
##                    Design:            without Test bench
##                    DCM Used:          Enable
##                    Two Bytes per Bank:Disable
##                    No.Of Controllers: 1
# Clock constraints                                                        #
NET "*/u_ddr2_infrastructure/sys_clk_ibufg" TNM_NET =  "SYS_CLK";
TIMESPEC "TS_SYS_CLK" = PERIOD "SYS_CLK" 5 ns HIGH 50 %;
NET "*/u_ddr2_infrastructure/clk200_ibufg" TNM_NET = "SYS_CLK_200";
TIMESPEC "TS_SYS_CLK_200" = PERIOD "SYS_CLK_200" 5 ns HIGH 50 %;
NET  "rx"                                                   LOC = "AG15";          # Bank 4, Vcco=3.3V, No DCI
NET  "tx"                                               LOC = "AG20";          # Bank 4, Vcco=3.3V, No DCI
#NET "trans" PULLUP;
NET  "led_p"                                           LOC = "AG23";
# Controller 0
# Memory Device: DDR2_SDRAM->SODIMMs->MT4HTF3264HY-667 #
# Data Width:     64 #
# Data Mask:     1 #
# I/O STANDARDS
NET  "ddr2_dq[*]"                               IOSTANDARD = SSTL18_II_DCI;
NET  "ddr2_a[*]"                                IOSTANDARD = SSTL18_II;
NET  "ddr2_ba[*]"                               IOSTANDARD = SSTL18_II;
NET  "ddr2_ras_n"                               IOSTANDARD = SSTL18_II;
NET  "ddr2_cas_n"                               IOSTANDARD = SSTL18_II;
NET  "ddr2_we_n"                                IOSTANDARD = SSTL18_II;
NET  "ddr2_cs_n[*]"                             IOSTANDARD = SSTL18_II;
NET  "ddr2_odt[*]"                              IOSTANDARD = SSTL18_II;
NET  "ddr2_cke[*]"                              IOSTANDARD = SSTL18_II;
NET  "ddr2_dm[*]"                               IOSTANDARD = SSTL18_II_DCI;
NET  "sys_clk_p"                                IOSTANDARD = LVPECL_25;
NET  "sys_clk_n"                                IOSTANDARD = LVPECL_25;
NET  "clk200_p"                                 IOSTANDARD = LVPECL_25;
NET  "clk200_n"                                 IOSTANDARD = LVPECL_25;
NET  "sys_rst_n"                                IOSTANDARD = LVCMOS18;
#NET  "phy_init_done"                            IOSTANDARD = LVCMOS18;
NET  "ddr2_dqs[*]"                              IOSTANDARD = DIFF_SSTL18_II_DCI;
NET  "ddr2_dqs_n[*]"                            IOSTANDARD = DIFF_SSTL18_II_DCI;
NET  "ddr2_ck[*]"                               IOSTANDARD = DIFF_SSTL18_II;
NET  "ddr2_ck_n[*]"                             IOSTANDARD = DIFF_SSTL18_II;
# Location Constraints
NET  "ddr2_dq[0]"                                LOC = "C20" ;          #Bank 23
NET  "ddr2_dq[1]"                                LOC = "B20" ;          #Bank 23
NET  "ddr2_dq[2]"                                LOC = "B21" ;          #Bank 23
NET  "ddr2_dq[3]"                                LOC = "A21" ;          #Bank 23
NET  "ddr2_dq[4]"                                LOC = "C18" ;          #Bank 23
NET  "ddr2_dq[5]"                                LOC = "C22" ;          #Bank 23
NET  "ddr2_dq[6]"                                LOC = "B22" ;          #Bank 23
NET  "ddr2_dq[7]"                                LOC = "B18" ;          #Bank 23
NET  "ddr2_dq[8]"                                LOC = "C23" ;          #Bank 23
NET  "ddr2_dq[9]"                                LOC = "B23" ;          #Bank 23
NET  "ddr2_dq[10]"                               LOC = "A19" ;          #Bank 23
NET  "ddr2_dq[11]"                               LOC = "A20" ;          #Bank 23
NET  "ddr2_dq[12]"                               LOC = "A24" ;          #Bank 23
NET  "ddr2_dq[13]"                               LOC = "D26" ;          #Bank 23
NET  "ddr2_dq[14]"                               LOC = "C27" ;          #Bank 23
NET  "ddr2_dq[15]"                               LOC = "A29" ;          #Bank 23
NET  "ddr2_dq[16]"                               LOC = "C28" ;          #Bank 23
NET  "ddr2_dq[17]"                               LOC = "D27" ;          #Bank 23
NET  "ddr2_dq[18]"                               LOC = "B31" ;          #Bank 23
NET  "ddr2_dq[19]"                               LOC = "A31" ;          #Bank 23
NET  "ddr2_dq[20]"                               LOC = "D29" ;          #Bank 23
NET  "ddr2_dq[21]"                               LOC = "D31" ;          #Bank 23
NET  "ddr2_dq[22]"                               LOC = "D30" ;          #Bank 23
NET  "ddr2_dq[23]"                               LOC = "A30" ;          #Bank 23
NET  "ddr2_dq[24]"                               LOC = "K24" ;          #Bank 19
NET  "ddr2_dq[25]"                               LOC = "L24" ;          #Bank 19
NET  "ddr2_dq[26]"                               LOC = "L25" ;          #Bank 19
NET  "ddr2_dq[27]"                               LOC = "L26" ;          #Bank 19
NET  "ddr2_dq[28]"                               LOC = "J25" ;          #Bank 19
NET  "ddr2_dq[29]"                               LOC = "M25" ;          #Bank 19
NET  "ddr2_dq[30]"                               LOC = "M26" ;          #Bank 19
NET  "ddr2_dq[31]"                               LOC = "J27" ;          #Bank 19
NET  "ddr2_dq[32]"                               LOC = "G25" ;          #Bank 19
NET  "ddr2_dq[33]"                               LOC = "G26" ;          #Bank 19
NET  "ddr2_dq[34]"                               LOC = "H25" ;          #Bank 19
NET  "ddr2_dq[35]"                               LOC = "H24" ;          #Bank 19
NET  "ddr2_dq[36]"                               LOC = "F26" ;          #Bank 19
NET  "ddr2_dq[37]"                               LOC = "K28" ;          #Bank 19
NET  "ddr2_dq[38]"                               LOC = "L28" ;          #Bank 19
NET  "ddr2_dq[39]"                               LOC = "K27" ;          #Bank 19
NET  "ddr2_dq[40]"                               LOC = "M28" ;          #Bank 19
NET  "ddr2_dq[41]"                               LOC = "N28" ;          #Bank 19
NET  "ddr2_dq[42]"                               LOC = "P26" ;          #Bank 19
NET  "ddr2_dq[43]"                               LOC = "P27" ;          #Bank 19
NET  "ddr2_dq[44]"                               LOC = "P24" ;          #Bank 19
NET  "ddr2_dq[45]"                               LOC = "P25" ;          #Bank 19
NET  "ddr2_dq[46]"                               LOC = "N25" ;          #Bank 19
NET  "ddr2_dq[47]"                               LOC = "R24" ;          #Bank 19
NET  "ddr2_dq[48]"                               LOC = "E29" ;          #Bank 15
NET  "ddr2_dq[49]"                               LOC = "F29" ;          #Bank 15
NET  "ddr2_dq[50]"                               LOC = "G30" ;          #Bank 15
NET  "ddr2_dq[51]"                               LOC = "F30" ;          #Bank 15
NET  "ddr2_dq[52]"                               LOC = "J29" ;          #Bank 15
NET  "ddr2_dq[53]"                               LOC = "F31" ;          #Bank 15
NET  "ddr2_dq[54]"                               LOC = "E31" ;          #Bank 15
NET  "ddr2_dq[55]"                               LOC = "L29" ;          #Bank 15
NET  "ddr2_dq[56]"                               LOC = "H30" ;          #Bank 15
NET  "ddr2_dq[57]"                               LOC = "G31" ;          #Bank 15
NET  "ddr2_dq[58]"                               LOC = "J30" ;          #Bank 15
NET  "ddr2_dq[59]"                               LOC = "J31" ;          #Bank 15
NET  "ddr2_dq[60]"                               LOC = "M30" ;          #Bank 15
NET  "ddr2_dq[61]"                               LOC = "T31" ;          #Bank 15
NET  "ddr2_dq[62]"                               LOC = "R31" ;          #Bank 15
NET  "ddr2_dq[63]"                               LOC = "U30" ;          #Bank 15
NET  "ddr2_a[12]"                                LOC = "B30" ;          #Bank 23
NET  "ddr2_a[11]"                                LOC = "T24" ;          #Bank 19
NET  "ddr2_a[10]"                                LOC = "P31" ;          #Bank 15
NET  "ddr2_a[9]"                                 LOC = "P30" ;          #Bank 15
NET  "ddr2_a[8]"                                 LOC = "M31" ;          #Bank 15
NET  "ddr2_a[7]"                                 LOC = "N30" ;          #Bank 15
NET  "ddr2_a[6]"                                 LOC = "T28" ;          #Bank 15
NET  "ddr2_a[5]"                                 LOC = "T29" ;          #Bank 15
NET  "ddr2_a[4]"                                 LOC = "U27" ;          #Bank 15
NET  "ddr2_a[3]"                                 LOC = "U28" ;          #Bank 15
NET  "ddr2_a[2]"                                 LOC = "R26" ;          #Bank 15
NET  "ddr2_a[1]"                                 LOC = "R27" ;          #Bank 15
NET  "ddr2_a[0]"                                 LOC = "U26" ;          #Bank 15
NET  "ddr2_ba[1]"                                LOC = "T26" ;          #Bank 15
NET  "ddr2_ba[0]"                                LOC = "U25" ;          #Bank 15
NET  "ddr2_ras_n"                                LOC = "T25" ;          #Bank 15
NET  "ddr2_cas_n"                                LOC = "B32" ;          #Bank 11
NET  "ddr2_we_n"                                 LOC = "A33" ;          #Bank 11
NET  "ddr2_cs_n[0]"                              LOC = "B33" ;          #Bank 11
NET  "ddr2_odt[0]"                               LOC = "C33" ;          #Bank 11
NET  "ddr2_cke[0]"                               LOC = "C32" ;          #Bank 11
NET  "ddr2_dm[0]"                                LOC = "C19" ;          #Bank 23
NET  "ddr2_dm[1]"                                LOC = "A23" ;          #Bank 23
NET  "ddr2_dm[2]"                                LOC = "C30" ;          #Bank 23
NET  "ddr2_dm[3]"                                LOC = "J24" ;          #Bank 19
NET  "ddr2_dm[4]"                                LOC = "F25" ;          #Bank 19
NET  "ddr2_dm[5]"                                LOC = "N24" ;          #Bank 19
NET  "ddr2_dm[6]"                                LOC = "H29" ;          #Bank 15
NET  "ddr2_dm[7]"                                LOC = "L30" ;          #Bank 15
NET  "sys_clk_p"                                 LOC = "H17" ;          #Bank 3
NET  "sys_clk_n"                                 LOC = "H18" ;          #Bank 3
NET  "clk200_p"                                  LOC = "K17" ;          #Bank 3
NET  "clk200_n"                                  LOC = "L18" ;          #Bank 3
NET  "sys_rst_n"                                 LOC = "D32" ;          #Bank 11
#NET  "phy_init_done"                             LOC = "C34" ;          #Bank 11
NET  "ddr2_dqs[0]"                               LOC = "C24" ;          #Bank 23
NET  "ddr2_dqs_n[0]"                             LOC = "D25" ;          #Bank 23
NET  "ddr2_dqs[1]"                               LOC = "B26" ;          #Bank 23
NET  "ddr2_dqs_n[1]"                             LOC = "A25" ;          #Bank 23
NET  "ddr2_dqs[2]"                               LOC = "B27" ;          #Bank 23
NET  "ddr2_dqs_n[2]"                             LOC = "A26" ;          #Bank 23
NET  "ddr2_dqs[3]"                               LOC = "G27" ;          #Bank 19
NET  "ddr2_dqs_n[3]"                             LOC = "H27" ;          #Bank 19
NET  "ddr2_dqs[4]"                               LOC = "H28" ;          #Bank 19
NET  "ddr2_dqs_n[4]"                             LOC = "G28" ;          #Bank 19
NET  "ddr2_dqs[5]"                               LOC = "E28" ;          #Bank 19
NET  "ddr2_dqs_n[5]"                             LOC = "F28" ;          #Bank 19
NET  "ddr2_dqs[6]"                               LOC = "N29" ;          #Bank 15
NET  "ddr2_dqs_n[6]"                             LOC = "P29" ;          #Bank 15
NET  "ddr2_dqs[7]"                               LOC = "K31" ;          #Bank 15
NET  "ddr2_dqs_n[7]"                             LOC = "L31" ;          #Bank 15
NET  "ddr2_ck[0]"                                LOC = "B25" ;          #Bank 23
NET  "ddr2_ck_n[0]"                              LOC = "C25" ;          #Bank 23
NET  "ddr2_ck[1]"                                LOC = "E26" ;          #Bank 19
NET  "ddr2_ck_n[1]"                              LOC = "E27" ;          #Bank 19
# Define multicycle paths - these paths may take longer because additional
# time allowed for logic to settle in calibration/initialization FSM
# MIG 2.1: Eliminate Timegroup definitions for CLK0, and CLK90. Instead trace
#          multicycle paths from originating flip-flop to ANY destination
#          flip-flop (or in some cases, it can also be a BRAM)
# MUX Select for either rising/falling CLK0 for 2nd stage read capture
INST "*/u_phy_calib/gen_rd_data_sel*.u_ff_rd_data_sel" TNM = "TNM_RD_DATA_SEL";
TIMESPEC "TS_MC_RD_DATA_SEL" = FROM "TNM_RD_DATA_SEL" TO FFS
"TS_SYS_CLK" * 4;
# MUX select for read data - optional delay on data to account for byte skews
INST "*/u_usr_rd/gen_rden_sel_mux*.u_ff_rden_sel_mux" TNM = "TNM_RDEN_SEL_MUX";
TIMESPEC "TS_MC_RDEN_SEL_MUX" = FROM "TNM_RDEN_SEL_MUX" TO FFS
"TS_SYS_CLK" * 4;
# Calibration/Initialization complete status flag (for PHY logic only) - can
# be used to drive both flip-flops and BRAMs
INST "*/u_phy_init/u_ff_phy_init_data_sel" TNM = "TNM_PHY_INIT_DATA_SEL";
TIMESPEC "TS_MC_PHY_INIT_DATA_SEL_0" = FROM "TNM_PHY_INIT_DATA_SEL" TO FFS
"TS_SYS_CLK" * 4;
TIMESPEC "TS_MC_PHY_INIT_DATA_SEL_90" = FROM "TNM_PHY_INIT_DATA_SEL" TO RAMS
"TS_SYS_CLK" * 4;
# Select (address) bits for SRL32 shift registers used in stage3/stage4
# calibration
INST "*/u_phy_calib/gen_gate_dly*.u_ff_gate_dly" TNM = "TNM_GATE_DLY";
TIMESPEC "TS_MC_GATE_DLY" = FROM "TNM_GATE_DLY" TO FFS "TS_SYS_CLK" * 4;
INST "*/u_phy_calib/gen_rden_dly*.u_ff_rden_dly" TNM = "TNM_RDEN_DLY";
TIMESPEC "TS_MC_RDEN_DLY" = FROM "TNM_RDEN_DLY" TO FFS "TS_SYS_CLK" * 4;
INST "*/u_phy_calib/gen_cal_rden_dly*.u_ff_cal_rden_dly"
  TNM = "TNM_CAL_RDEN_DLY";
TIMESPEC "TS_MC_CAL_RDEN_DLY" = FROM "TNM_CAL_RDEN_DLY" TO FFS
"TS_SYS_CLK" * 4;
#The following constraint is added to prevent (false) hold time violations on
#the data path from stage1 to stage2 capture flops.  Stage1 flops are clocked by
#the delayed DQS and stage2 flops are clocked by the clk0 clock. Placing a TIG
#on the DQ IDDR capture flop instance to achieve this is acceptable because timing
#is guaranteed through the use of separate Predictable IP constraints. These
#violations are reported when anunconstrained path report is run.
INST "*/gen_dq[*].u_iob_dq/gen*.u_iddr_dq" TIG ;
# DQS Read Post amble Glitch Squelch circuit related constraints
# LOC placement of DQS-squelch related IDDR and IDELAY elements
# Each circuit can be located at any of the following locations:
#  1. Unused "N"-side of DQS differential pair I/O
#  2. DM data mask (output only, input side is free for use)
#  3. Any output-only site
INST "*/gen_dqs[0].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y302";
INST "*/gen_dqs[0].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y302";
INST "*/gen_dqs[1].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y300";
INST "*/gen_dqs[1].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y300";
INST "*/gen_dqs[2].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y298";
INST "*/gen_dqs[2].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y298";
INST "*/gen_dqs[3].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y262";
INST "*/gen_dqs[3].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y262";
INST "*/gen_dqs[4].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y260";
INST "*/gen_dqs[4].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y260";
INST "*/gen_dqs[5].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y258";
INST "*/gen_dqs[5].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y258";
INST "*/gen_dqs[6].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y222";
INST "*/gen_dqs[6].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y222";
INST "*/gen_dqs[7].u_iob_dqs/u_iddr_dq_ce"  LOC = "ILOGIC_X0Y220";
INST "*/gen_dqs[7].u_iob_dqs/u_iodelay_dq_ce"  LOC = "IODELAY_X0Y220";
# LOC and timing constraints for flop driving DQS CE enable signal
# from fabric logic. Even though the absolute delay on this path is
# calibrated out (when synchronizing this output to DQS), the delay
# should still be kept as low as possible to reduce post-calibration
# voltage/temp variations - these are roughly proportional to the
# absolute delay of the path.
#    The following code has been commented for V5 as the predictable IP will take
#    care of placement of these flops by meeting the MAXDELAY requirement.
#    These constraints will be removed in the next release.
INST "*/u_phy_calib/gen_gate[0].u_en_dqs_ff"  LOC = SLICE_X0Y151;
INST "*/u_phy_calib/gen_gate[1].u_en_dqs_ff"  LOC = SLICE_X0Y150;
INST "*/u_phy_calib/gen_gate[2].u_en_dqs_ff"  LOC = SLICE_X0Y149;
INST "*/u_phy_calib/gen_gate[3].u_en_dqs_ff"  LOC = SLICE_X0Y131;
INST "*/u_phy_calib/gen_gate[4].u_en_dqs_ff"  LOC = SLICE_X0Y130;
INST "*/u_phy_calib/gen_gate[5].u_en_dqs_ff"  LOC = SLICE_X0Y129;
INST "*/u_phy_calib/gen_gate[6].u_en_dqs_ff"  LOC = SLICE_X0Y111;
INST "*/u_phy_calib/gen_gate[7].u_en_dqs_ff"  LOC = SLICE_X0Y110;
# Control for DQS gate - from fabric flop. Prevent "runaway" delay -
# two parts to this path: (1) from fabric flop to IDELAY, (2) from
# IDELAY to asynchronous reset of IDDR that drives the DQ CE's
# This can be relaxed by the user for lower frequencies:
# 300MHz = 850ps, 267MHz = 900ps. At 200MHz = 950ps.
# In general PAR should be able to route this
# within 900ps over all speed grades.
NET "*/u_phy_io/en_dqs[*]" MAXDELAY = 600 ps;
NET "*/u_phy_io/gen_dqs*.u_iob_dqs/en_dqs_sync" MAXDELAY = 850 ps;
# "Half-cycle" path constraint from IOB flip-flop to CE pin for all DQ IDDR's
# for DQS Read Post amble Glitch Squelch circuit
# Max delay from output of IOB flip-flop to CE input of DQ IDDRs =
#  tRPST + some slack where slack account for rise-time of DQS on board.
#  For now assume slack = 0.400ns (based on initial SPICE simulations,
#  assumes use of ODT), so time = 0.4*Tcyc + 0.40ns = 1.6ns @333MHz
INST "*/gen_dqs[*].u_iob_dqs/u_iddr_dq_ce" TNM = "TNM_DQ_CE_IDDR";
INST "*/gen_dq[*].u_iob_dq/gen_stg2_*.u_iddr_dq" TNM = "TNM_DQS_FLOPS";
TIMESPEC "TS_DQ_CE" = FROM "TNM_DQ_CE_IDDR" TO "TNM_DQS_FLOPS" 2.4 ns;
And the erro that I have is the following:
 Phase  1  : 7557 unrouted;      REAL time: 11 secs
ERROR:Route:537 -  A core generated by the Memory Interface Generator (MIG) has been detected in this design  but PAR is unable to route the critical signals of this core to meet the necessary skew and delay  requirements. Please ensure that there are no location constraints or Directed Routing constraints   on the MIG core logic/routes that could conflict with automatic placement and routing. To generate   an NCD that can be used for debugging in FPGA Editor, please re-run PAR with the environme
nt variable  XIL_PAR_DISABLE_MIG_ANALYSIS 1. Note that if this NCD is used, the design can fail in hardware.   Below is the list of nets in which PAR had problems routing optimally:
| Sig: u_mem_controller/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[0].u_iob_dq/stg1_out_fall_sg1
| Sig: u_mem_controller/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[0].u_iob_dq/stg1_out_rise_sg1
| Sig: u_mem_controller/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[1].u_iob_dq/stg1_out_rise_sg1
| Sig: u_mem_controller/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[4].u_iob_dq/stg1_out_rise_sg1
| Sig: u_mem_controller/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[7].u_iob_dq/stg1_out_rise_sg1
I don't know what I have to do to change the environment variable .... or to solve this prolem
Thank you very much inadvance.....
Emilio
So you used the "Create Design" flow in MIG for this, correct?  And then did you change the UCF to match the ML507 board?  If so, you are missing a step.  After you change the UCF for the board, you need to go back into MIG and run the "Verify and Update UCF" to get an updated UCF and the HDL that goes with it.
If you used a different flow, let us know and perhaps we can suggest something else.  For a faster response, I do suggest you open a Webcase with Xilinx.
I am facing similar problem flow of using mig is
I careated MIG from core gen and I import it in edk
my design have only mig + Uart + clks that need to connect external i/os
I am facing error
    an NCD that can be used for debugging in FPGA Editor, please re-run PAR with the environment variable
| Sig: mig_33_0/mig_33_0/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[0].u_iob_dq/stg1_out_rise_sg2
| Sig: mig_33_0/mig_33_0/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[0].u_iob_dq/stg1_out_fall_sg2
| Sig: mig_33_0/mig_33_0/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[5].u_iob_dq/stg1_out_fall_sg2
| Sig: mig_33_0/mig_33_0/u_ddr2_top_0/u_mem_if_top/u_phy_top/u_phy_io/gen_dq[5].u_iob_dq/stg1_out_rise_sg2
I am looking for script that can update ucf file
i am trying to update it using coregen but its is asking for ise project
and not suppport system.prj file
