Visitor tsr3944
Program Device Error ZCU102
I have a ZCU102 board. I am trying out the Xilinx IBERT tutorial. I am following all the steps shown no issues until towards the end.
When I generate my bit-stream, I generate without any errors (only a few warning).
After that, I go ahead to the process to uploading it into my board.
However, when I click "Program Device" to upload my program onto my device, I get this error "[Labtools 27-3176]-hw_server failed during internal command".
Has anyone encountered this error before? Can you tell me what the error is this and why am I getting this error? What can I do to solve this issue?
I am not developing anything new, I am just following Xilinx's IBERT tutorial step by step and I am encountering this error at the very end when I try to upload the program onto the board.
Thank you!
Re: Program Device Error ZCU102
Hi tsr3944,
Can you provide the full output? Are there any errors before that one?
Andres
Hello @tsr3944,
Can you please share the following details with us:
1. Which Vivado version you using?
2. Did you follow the steps which is mentioned in the ug936 ?
3. What is the line rate you are targeting?
4. Please share the log file with us.
5. Try to run the example design from below link:
(https://www.xilinx.com/member/forms/download/design-license.html?cid=62103ce1-62b9-4831-8979-00cc9290ae34&filename=rdf0379-zcu102-ibert-c-2018-2.zip)
Naveen
Visitor tsr3944
I an using Vivado 2018.2
I have not yet gone through the Lab 10 debug process but I will now.
I am using the example Line Rate = 10.3125 Gbps given for SFP IBERT Tutorial (XTP430)
I believe these are the files...attached.
Okay, I will do this next. Thanks!
