Observer manojdaran
Suggest a CPU Cabinet for VCU1525
Hello forum, I have to mount VCU1525 in CPU cabinet. Im having trouble finding a suitable one. Please suggest me a cabinet where I can fix motherboard and VCU1525 with good cooling fans.
Re: Suggest a CPU Cabinet for VCU1525
Hello @manojdaran,
Hope we answered your query about VCU1525.
Can you please conclude this post by marking the appropriate post as accepted solution ?
Thank you
Scholar drjohnsmith
where have you looked ?
its a standard PCIe card,
ok the largest size, but still a standard
Observer manojdaran
Any full tower cabinet will be sufficient?
Hello @manojdaran,
VCU1525 has 16 lane PCIe connector on board.
We have also mentioned board dimensions in the user guide.
Also I will recommend you to check the SMPS supply of the host machine. It should be compatible to power the VCU1525 considering its power consumption. Refer UG1268 which is a board user guide for more help.
Thank you
Hello @manojdaran,
Thank you
