TclStackFree: incorrect freePtr. Call out of sequence?"
I have an error when trying to compile BIST project for ac701 EV board. I follow instruction xtp194-ac701-bist-c-2014-2.pdf, and after I reset synth_1 and then click "Generate Bitstream", after several tens of minutes I have error window and message in log: "TclStackFree: incorrect freePtr. Call out of sequence?".
What did I do wrong?
Windows 7, 64-bit, DELL Lattitude E6430.
Sorry for my bad english.
Re: TclStackFree: incorrect freePtr. Call out of sequence?"
Also, I am using Xilinx 2014.2 and fresh archive of BIST.
How can I edit messages on this forum?
What is RAM size of your system?
The most likely reason for this error could be lack of main memory.
did you check this answer record: http://www.xilinx.com/support/answers/55687.html
Also give a try by running synthesis with "Run time Optimized" strategy.
Vinay
8Gb.... It`s still a laptop, and we really dont want use desktop pc.
Accordingly to this: http://www.xilinx.com/design-tools/vivado/memory.htm#v7l
8Gb is more than enough...
I tried to run "set_param synth.elaboration.rodinMoreOptions {set rt::extractNetlistGenomes false}" before Synthesis, but with no luck.
Still no luck with both options "set_param synth.elaboration.rodinMoreOptions {set rt::extractNetlistGenomes false}"
and "run-time optimized"...
Trying 2013.3 version...
Can I open thread not in New Users forum, but in Design Tools forum?
Ugh... It`s impossible to open BIST broject, which I downloaded here, under 2013.3 vivado (which was shipped on DVD with board, by the way). Where I can get old version of BIST project? Or even any other little project, which I could compile? Can anyone help me?
We buy most expencive board and it`s completle unusable....
"INFO: [Synth 8-256] done synthesizing module 'ac701_ethernet_rgmii_block' (53#1) [c:/Karnaukhov/FPGA/Ethernet/Ethernet.srcs/sources_1/ip/ac701_ethernet_rgmii/synth/ac701_ethernet_rgmii_block.v:108]
INFO: [Synth 8-256] done synthesizing module 'ac701_ethernet_rgmii' (54#1) [c:/Karnaukhov/FPGA/Ethernet/Ethernet.srcs/sources_1/ip/ac701_ethernet_rgmii/synth/ac701_ethernet_rgmii.v:66]
Ethernet tutorial (XTP223) cant be compiled too....
Solved...
Your programmers should be punished, they make classical error)
Newbie kaziewip
How did you manage to solve this problem?
It's infuriating me as I have a powerful PC running Windows-64 bit and just want to test the Basys3 I've just bought.
Hi @alexkarnaukhov ,
Plese post the solution and mark the solution in the interest of other users.
Thanks,Vijay
The problem is with non-latin letters in Windows computer name. Just go to computer properties, change it to latin-only word and reboot computer.
Newbie caesarkof97
It works, thank you very much!
