Visitor harsha_304
Unable to create a bootable boot.bin for a generated bit file in SD-Card mode ZCU102 in 2017.4 toolset Windows
I am working on the Zynq Ultrascale+ MPSoc, ZCU102 Revision 1.1.
I have copied the pre-built images into the SD-Card and ran it on the board. The board boots fine with the pre-built images.
Now, I have written an FPGA code for which a bit file is also created.
I have used the http://www.wiki.xilinx.com/ZCU102+Image+creation+in+OSL+flow
link to find the order for the files to be added for boot image creation in Xilinx SDK 2017.4(in Windows).
order I followed is:
fsbl
bit file
pmufw_image
bl31
u-boot.elf
Except for the bit file, I have used the other set of pre-built images from "2017.1-zcu102-release.tar.xz" section of http://www.wiki.xilinx.com/Zynq+2017.1+Release link.
After creating the boot image and copying it onto SD-Card, the board is not booting.
Below is what I am observing in the terminal:
øXilinx Zynq MP First Stage Boot Loader
Release 2017.4 Feb 22 2018 - 17:30:28
XPFW: Calling ROM PWRUP Handler..Done
XPFW: Calling ROM Isolation Handler..Done
On the board,I am able to observe INIT_B LED and PS_ERR_OUT LED glowing "RED".
Can I know where where I am wrong with Boot Image creation?
or If the procedure is wrong, can you point me in the proper direction?
Scholar austin
Re: Unable to create a bootable boot.bin for a generated bit file in SD-Card mode ZCU102 in 2017.4 toolset Windows
All tools and images must use (be generated from 2017.4),
You cannot mix & match.
Tools must be consistent.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor harsha_304
    Thank you for the response.
I have followed all the steps from
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1209-embedded-design-tutorial.pdf
link.
The issue I had was with the security firmware file.
I started using the one from the above link and the board started to boot.
