Using GTH on ZCU102 board
I want to send 6Gps data from 1 zcu102 to another zcu102 board. However, I am a totally new for GTH/GTX/GTY technology. So I have several questions
- Is it enough to use just 1 (or 2) GTH ? if yes, which protocol should I use?
- Can GTH transmit over 10' cable?
- Is there any design example for zcu102 for GTH so that I can run the test, and learn from it.
Very appreciate any answer.
Andrew
Re: Using GTH on ZCU102 board
Hello @andrewngo,
I will request you to refer the DS925 for different PS as well as PL transceiver performances.
There you can find the maximum line supported by each GTH/ GTX/ GTY.
Also you can run XTP430 which is IBERT example design to test the transceivers on ZCU102 board.
Hope this helps.
Thank you.
Hello @andrewngo,
Hope this helps.
Thank you.
@kvasantr
Thank you for your hint, I will start with IBERT Example Design first.
Andrew
