VC707 BPI flash error
Hi, I am trying to restore vc707 flash according to guide xtp208-vc707-restoring-flash-c-2015-1.pdf, but encountered error as attach file. Could you please help? Thanks in advance.
回复: VC707 BPI flash error
Hi bo-bai@rack-system.cn,
According to the log, BPI erase operation wasn''t successful. Did you try erase the BPI in Vivado GUI?
Simon
Yes. I have tried in GUI. It encountered the same error. I can confirm the SW11 mode setting is correct. I have flashed successfully once and it can work. But when I tried to do again, it alwasys failed. Thanks.
This is error information when I tried to flash BPI using Vivado GUI. Thanks.
Hello bo-bai@rack-system.cn
Try disabling verify option while programming flash from Viavdo and let us know results.
Bhushan
I just disabled 'Verify' and tried program again, but the error is same. Thanks.
All Bist test passed except flash test. Thanks.
It indicates that Flash can't be erased and therefore it can't be programmed again.
Simon
Then what's the solution? Return to factory? Thanks.
I am developing PCIe and DDR solution and have to program BPI flash to make the board discovery by host PC. Then what can I do? I just received the board 3 days. Thanks.
