Observer ajroth
VC707 GTX QUAD113 SFP use Si5324, SGMII use SGMII _CLK - UG476 single external ref clk confusion
VC707 - Vivado ~2014.2 tools (trying 2015.1 or 2 evantually as well..)
What is the best way to generate cores to have both the VC707 GTX SFP use Si5324 and SGMII use SGMII _CLK since both are in QUAD113.  The Si5324 clk is from MGTREFCLK0 QUAD114 while the SGMII_CLK is from MGTREFCLK0 QUAD113.
I have the SGMII ethernet / PCS/PMA working via AR59968 TEMAC PSCPMA -
1- However I generated the "core with shared logic" for the pcs/pma core for SGMII, do I need to go back and change this?
Now for the Si5324 clk coming in which I know is good seen via a probe I have the following questions:
2- Should I configure the signal from the Si5324 to be "Low swing LVDS", LVDS, or LVPECL?  I'm guessing Low swing LVDS should be good after looking at things.
3- I've generated the core without shared logic - and instantiate the IBUFDS_GTE2 and tried tying this to both gt0_gtrefclk0_in/1, and the gtsouthrefclk0/1 in.  It doesn't appear to map to gtrefclk0 or 1 when I tie it to those when viewing the routed design in device view...
I've noticed documentation UG476:
"Figure 2-6 shows a single external reference clock with multiple transceivers in multiple
Quads. The user design connects the IBUFDS_GTE2 output (O) to the GTREFCLK0 ports
of the GTXE2_COMMON and GTXE2_CHANNEL primitives for the GTX transceiver, and
GTHE2_COMMON and GTHE2_CHANNEL primitives for the GTH transceiver. In this
case, the Xilinx implementation tools make the necessary adjustments to the north/south
routing as well as pin swapping necessary to route the reference clocks from one Quad to
another when required."
4- Do I need to instantiate GTXE_COMMON as well even though I don't want/need the QPLL clk I just want to use the CPLL clk?
5- Is tieing the IBUFDS_GTE2 output to only gt0_gtgrefclk0_in the correct path, and all the others tie to gnd?
6- Will there not be a conflict with the SGMII_CLK which the SGMII using from gtefclk0_in? - do I need to modify anything on my working PCS/PMA core? (source files are encrypted for the GTX gtwizard for the pcs/pma SGMII core?! so I can't see what it was set up as...)
Thanks - this works in simulation, but I can't get CPLL lock.  You may reference further background at http://forums.xilinx.com/t5/Connectivity/GTX-transceiver-wizard-set-CPLLREFCLK-quot-101-quot-in-property/m-p/643571#M8223 which was a different beginning question to figure out how to get clks here (feed si570 to si5324)
Observer ajroth
Re: VC707 GTX QUAD113 SFP use Si5324, SGMII use SGMII _CLK - UG476 single external ref clk confusion
Solved -
Answers/hints for future viewers:
1- no
2- Low swing LVDS working
3- Geberate without advanced clk - tie only gtrefclk0 to output of IBUFDS_GTE2 and tools map it automatically as needed to SOUTHREFCLK you can see in device viewer,  but you don't need to tough CPLLREFSEL's or SOUTHREFCLK signals..
4- no
5- yes, just tie the GTREFCLK0
6- ok
Observer ajroth
Solved -
1- no
4- no
6- ok
