VCU108 EVM IPI Bitstream Generation
I am following XTP363 document to re-generate the bitstream. I have compiled the design and generated the ELF file using SDK and then clicked on "Generate Bitstream" to generate bitstream with IPI ELF file. Afterwards I am getting following error message on Vivado.
[Netlist 29-347] Unable to write file because the following cells are unlicensed: system_i/colorbar_tpg_hier_0/v_tpg_0/inst (system_v_tpg_0_0_v_tpg)
Can you please let us know how to avoid the same?
Raja
Re: VCU108 EVM IPI Bitstream Generation
Its seems licensing issue . You need to make sure you have valid license
https://www.xilinx.com/support/answer-navigation/design-tools/licensing.html
Thanks and Regards
Balkrishan
Newbie randy.brown
I also get the same error, but I am generating a bitstream for the KCU105_ipi project. I have a Node Locked License.
