VCU1525 Default Bitfile
Which design has been loaded from factory on VCU1525 board?
Shreyas
Observer josecm
Re: VCU1525 Default Bitfile
I would also like to know about this!
Hello sshah@esperantotech.com and @josecm,
It should have system controller utility on board. which can be accessible through UART.
By setting the tera term for the dedicated UART  port for system controller; one can setup the board features.
If you are accessing the board for the very first time. Please follow below link for more help:
https://www.xilinx.com/html_docs/xilinx2017_4/sdaccel_doc/xdw1504034340451.html
Thank you.
