VCU1525 compilation
I get following error while compiling for VCU1525 board.
[Common 17-70] Application Exception: Number of active netlists exceeds limit (255)
[BD 41-1030] Generation failed for the IP Integrator block ddr4_1
[BD 41-1030] Generation failed for the IP Integrator block ddr4_2
[BD 41-1030] Generation failed for the IP Integrator block ddr4_3
[Vivado 12-4756] Launch of runs aborted due to earlier errors while preparing sub-designs for run execution.
Any help appreciated.
Shreyas
Re: VCU1525 compilation
What version of the tools? Do you get this with all designs or just one?
I use 2018.1 on Ubuntu 16.1
Shreyas
