Observer manojdaran
VCU1525 temperature monitor
In VCU1525 I have connected DC1613A from Linear tech for voltage control. In the dashboard, there are 2 different temperature reading, Im unsure what is that. The two values read as follows
READ_TEMPERATURE_1_PAGED
READ_TEMPERATURE_2
Some people said, they are inductor temperature. Somebody please clarify
regards
Re: VCU1525 temperature monitor
Can you post a screenshot of the dashboard? I am also curious what cable you are using, do you have a part number?
READ_TEMPERATURE_1_PAGED:
This reads the inductor temperatures
READ_TEMPERATURE_2:
This reads the LTC3884 internal die temperature
Observer manojdaran
Is there any maximum temperature that inductors/internal die can take? Im curious to know.
PS: The cable that I used SAM8218-ND
Observer manojdaran
What I mean is the killing temperature of the inductors/internal die
Hello @manojdaran,
Temperature range for LTC3884 and LM96063 on board is very high compared to the actual operating temperature range of VCU1525 acceleration card which is
• Operating: 0°C to +45°C
• Storage: –25°C to +60°C
Refer the datasheets of those diodes for operating temperatures.
http://www.ti.com/lit/ds/symlink/lm96063.pdf
https://www.analog.com/media/en/technical-documentation/data-sheets/3884fe.pdf
But they have been configured to shutdown the system for above operating temperatures.
Thank you.
