VCU1525 vivado hardware manager detection problem
We recently purchased a VCU1525 development board, after connecting it properly via the PCIe slot the vivado hardwaremanager 2018.2 was not able to see the VU9P FPGA.
Adding the AUX power did not solve the issue.
the error given by Vivado hw manager is the following:
ERROR: [Labtools 27-2269] No devices detected on target localhost:3121/xilinx_tcf/Xilinx/12809621t026A.
Check cable connectivity and that the target board is powered up then
use the disconnect_hw_server and connect_hw_server to re-register this hardware target.
ERROR: [Common 17-39] 'open_hw_target' failed due to earlier errors.
any hints??
cheers,
Re: VCU1525 vivado hardware manager detection problem
Hi @wmansour
Provide status of following LED's
Reference designator
                  Description
DS1
RED:POWER GOOD
DS2
BLUE:DONE_0
DS3
RED:STATUS_LED0
DS3
YELLOW:STATUS_LED1
DS3
GREEN:STATUS_LED2
When you connect micro USB on VCU1525 front panel to PC; Does any UART devices are appearing or detected by Device manager of PC?
Bhushan
Hi @bpatil
yes the UART is was detected by the PC.
the LEDs I have are RED, YELLOW, GREEN
Hi @wmansour
Did you try programming on different PC? OS details?
Try reinstalling cable driver (https://www.xilinx.com/support/answers/59128.html).
When you connect board through JTAG cable what do you at Vivado Hardware Manager? Provide snapshot.
Did this issue occurred at time zero?
Bhushan
hi @bpatil
reinstalling cable drivers did not solve the issue. The PC is a windows 7, and the hardware manger detects via USB jtag the KC705, and the KCU116
and via Xilinx JTAG plateform a VU9P on a custom board.
this issue happened at time zero.
