VGA Cable turning the USB off
I'm trying to learn how to do VGA Output on ZedBoard, but I'm struggling with a very weird problem.
The tutorial I'm following is this one http://blog.dev-flow.com/en/11-create-a-vga-controller-for-the-zedboard/
The problem I'm having is that when I try to connect both the VGA cable and my USB cable for programming the device in the Hardware Manager, the USB Cable keeps connecting and disconnecting. I also tried to unplug the VGA, program the device, unplug the USB then plug the VGA in the monitor but nothing happens on the screen.
If someone have any suggestion, i'll be very thankful.
Re: VGA Cable turning the USB off
Hi @tiago0297,
It looks like an issue with your Zedboard. In the design, there is no relationship between the VGA and the HW manager.
PS: I wrote this tutorial. You will find a newer version in my Video Series 1 ;)
Florent
