Scholar ronnywebers
Vivado 2017.2 board definition files for Zedboard
I'm using Vivado 2017.2 with a Zedboard, and when trying connection automation, i.e. to connect AXI GPIO pins to the leds or pushbuttons, things no longer work.
I tried zedboard.org first for an updated board def file, but the page says : Board Definition Files for the ZedBoard are preloaded into Vivado
Anyone using the Zedboard with 2017.2?
Re: Vivado 2017.2 board definition files for Zedboard
Hi @ronnywebers,
Could you give more information when you say "things no longer work". I have tried with 2017.2:
When I create a new project, I can select the board without getting the board file from AVNET:
And I am able to run connection automation without issues:
Just a sanity check: do you have all the check boxes enabled?
Hi @ronnywebers,
Scholar ronnywebers
Thanks @florentw, I think I just selected the Microzed board instead of Zedboard, I went over it again and now it works ... sorry for my stupidity :-)
