Visitor srv@xilinx
XADC in xilinx zedboard
In the XADC header its showing 17 external analog input channels can be given.
How to give them?
Scholar dpaul24
Re: XADC in xilinx zedboard
srv@xilinx,
For theory: https://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
An application user guide: https://www.xilinx.com/support/documentation/application_notes/xapp795-driving-xadc.pdf
FPGA enthusiast!
All PMs will be ignored
there is a plug in daughter board.
https://www.xilinx.com/products/boards-and-kits/hw-ams101-g.html
Keith
Visitor srv@xilinx
Ok. How many analog inputs can be given through this AMS101 evaluation board? I guess its 2 only.  ??
Visitor srv@xilinx
Suppose i have 20 analog inputs to work with. Can i feed these 20 analog inputs (to be processed) to zynq7000 zedboard? i mean in total (through Pmod, FMC, XADC)?
Scholar dpaul24
srv@xilinx,
Have you read the docu posted above? If yes, did you understand them?
You need to interpret your *use-case*.
https://www.xilinx.com/products/boards-and-kits/hw-ams101-g.html link says -
"Evaluates XADC 12-bit, 17-channel, 1Msps dual ADCs and Analog Mixed Signal technology"
FPGA enthusiast!
Visitor srv@xilinx
i have gone through its manual (AMS101). But i could not get how many analog inputs it will support?
pls help
Visitor srv@xilinx
yes its given 17 channel. But i am not getting where to give these 17 analog inputs. pls help
AMS101 will provide 1 ADC channel to VP/VN.
