Observer hhahn
ZC706 PSS IO pins
UG954:
The PCA9548 U65 RESET_B pin 24 is connected to FPGA U1 bank 501 pin F20 via
level-shifter U25. FPGA pin F20 net IIC_MUX_RESET_B_LS must be driven High to enable I2C bus
transactions with the devices connected to U65.
Qe.: Pin F20 is dedicated to PSS IO, so it can not be activated
        by the PL.
        What is the strategy to drive pin F20 by the PS IO ?
Thx
Ha
Re: ZC706 PSS IO pins
Hi @hhahn,
From schematics of ZC706 it looks like the reset is pull-up i.e. high by default.
So there is no need of additional logic. But if you are trying to toggle the pullup then need to write to MIO_46 register which connects to F20 using C application or direct register access appropriately.
Praveen
Hello @hhahn
This is written in UG954
Pin F20 controls U65 which is I2C bus transaction switch.
So if it's connected to PS IO developer or designer can write a logic which can be controlled over the processor part.
It can help to control the dynamic operation of I2C bus switch.
Hope this helps.
Observer hhahn
This is exactly what I  tried to do:  "designer can write a logic..."
So I defined a port   ICC_MUX_RESET_B_LS   in my Top Level design file.
But I got an LOC error during bitgen :
  port  ICC_MUX_RESET_B_LS   cannot be located   on pin F20.
So, how can this pin F20 be activated ?
thx
Ha
Observer hhahn
unfortunately I've got no answer which solves this problem:
=> Does anybody in the support team can answer this ?
Thx & rgds
Ha
Hi @hhahn,
Praveen
Observer hhahn
Hi Praveen,
Thank you, this will solve my problem !
rgds
Hans-W.
