Visitor bradtaylor
ZCU102 - Linux SD boot problems
I was excited to receive a new ZCU102 rev1.0 board today but I'm having some trouble bringing up linux via an SD card.
When I power up with the SD card installed or press the por_b switch, nothing seems to happen, except that the PS_ERR_OUT LED goes on.  Pretty sure this is user error, but I'm stuck now. Any suggestions? Perhaps someone could point me to a boot.bin file know to work on the new board?
Some additional details are listed below:
  • I set the SW6 Boot mode to SD mode - SW[4:1]=(0101) (on-off-on-off) as shown in the pic in the step-by-step guide
fyi - There is an additional jumper J108 which is not documented in the user guide near the SD card
Thanks in advance
Visitor joezhao
Re: ZCU102 - Linux SD boot problems
Just wonder how you can perform those tests if your system hanged there with PS_ERR_OUT red LED on. I got the eval board and there is nothing on SD card. I changed SW6 to boot from QSPI. After power cycle, the PS_ERR_OUT LED is turned on as red. The system wan hanged.
Visitor bradtaylor
Hi Joe - I was able to perform the self tests after I set SW6 to QSPI mode. Not quite sure what you mean by this statement below, but it would match my experience if you changed SW6 to boot from the SD card.
Visitor bradtaylor
Apparently the ZCU102 Rev 1.0 board has upgraded the SD card interface to support faster SD cards and the  simple SD boot mode = 0x5 will no longer function as I expected. Switching it to 0xE however works but there remain some issues with the version of linux builds. I will update this thread when we get Ubuntu up.
I too am having SD boot problems, like those described above.
I was able to get uboot via jtag but I get a "do not respond to voltage select" error
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.15.233 (256 ms)
Card did not respond to voltage select!
U-Boot-PetaLinux> run sdboot
boot Petalinux
syntax error
U-Boot-PetaLinux>
Did you figure out what J108 is?
I was able to get past the voltage error problem by reformatting the SD card.  Why that worked, I do not know.
Now I can read and write to the SD card from uboot initiated via jtag.  Still cannot boot via SD card.
Visitor doublesom
Hi @bradtaylor and @h_corey,
First thanks for the thread.
I managed to boot the ES2 board from SD card but the PS_ERROR_OUT is on.
Do you still have this issue?
doublesom
I did get it to boot using boot mode "E", but the ps error is on.  My Xilinx rep says they are looking into the erroneous error.
That is interesting i see you have been able to boot from SD Card in mode E.
For me, I could not boot from SD Card at all. I tried every possible mode, I tried different BOOT.bin images.
Nothing happens at the end. The board does not boot from SD Card.
Although using JTAG things are all looking fine.
Visitor doublesom
Hi All,
The following link http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2016.3 is the only document I have found where the boot mode SW6 switches on ES2 is given to boot from SD card.
My ES2 boards also will only boot with the mode set to 0xE.   I am able to boot the 2016.4 pre-built release and also able to boot my own custom distribution.
jeff
Participant nachiket
I'm also having trouble booting from sdcard. The self-test works fine. I'm able to connect via USB/UART. Irrespective of the SW6 options, I keep getting the following message on my terminal -->
!! Power Advantage Demo v1.00
!! Press ESC to enter System Controller mode.
I've tried 0x5 and 0xE to no avail.
Visitor zyxer
Hi All,
Similar issue with us. Any success in booting Linux with ZCU102 board?
Xilinx,
Any single reference to get Linux up and running on this ZCU102 board would be appreciated.
Visitor npalmer
nachiket,
You have probably moved on, but FYI, the Power Advantage Demo message is not coming from the Zynq, you have to switch Virtual Terminals.   You should have seen 4 ttys appear in dmesg when you connected the USB cable to a PC, try some of the others to see the Zynq PS UART output.    e.g. /dev/ttyUSB0, /dev/ttyUSB1, /dev/ttyUSB2, /dev/ttyUSB3
