Observer jialf521
ZCU102 board Si5341 reprogram
    The Si5341 on my ZCU102 board cannot work and I replaced it.How do you reprogram the (U69) SI5341B chip on the ZCU102 development board, or through what software can you access the chip.
Thank you
Re: ZCU102 board Si5341 reprogram
Hi @jialf521,
The Si5341/40 can be quickly and easily configured using ClockBuilderPro software. Custom part numbers are automatically assigned using a ClockBuilder Pro™ for fast, free, and easy factory pre-programming or the Si5341/40 can be programmed via I2C and SPI serial interfaces.
Please contact Silabs https://www.silabs.com for more information regarding this.
Deepak D N
Please reply or Give Kudos or mark it as an Accepted Solution.
Hi @jialf521,
through SCUI you can set the clock frequency of SI5341B. refer XTP433 for more information. and also download SCUI Files.
regards,
Deepak D N
Please reply or give kudos or mark it as a accepted solution.
Observer jialf521
Thank you @ddn
   Could you tell me more about it? I did not find a way to program SI5341B while using SCUI.
thanks
Observer jialf521
Observer jialf521
Thank you @ddn
     In SGUI, I can only set the output frequency of SI570 and SI5328.How to program SI5341 is also not covered in XTP433.
Hi @jialf521,
Deepak D N
