Visitor fllf2005
ZCU104 JTAG TCK frequency
what is the clock frequency for ZCU104 JTAG TCK? I do not find it in the documents.
Re: ZCU104 JTAG TCK frequency
Hi @fllf2005,
You should attempt to open with a default JTAG clock frequency that is 15 MHz for the
Digilent cable connection and 6 MHz for the USB cable connection. If it is not possible to
connect at these speeds, Xilinx recommends that you lower the default JTAG clock
frequency.
Hope this helps.
Deepak D N
Please reply or give kudo or Mark it as an Accepted Solution.
Hi @fllf2005,
frequency.
Hope this helps.
Deepak D N
