ZCU106 -ES board file not detected
I have a ES version of the ZCU106 board. I've retrieve from the xilinx web site the board file for Vivado 2018.1.
I copied the files into my vivado installation directory (Vivado/2018.1/data/boards/board_files/zcu106).
Restarted vivado, created a new project targetting the board.. unfortunately, I can't see the board... in the selection list.
(and yes, I've selected "view all" and not only "latest").
Does anybody knows how to solve this?
Sébastien
--Sebastien
Re: ZCU106 -ES board file not detected
Problem is solved by creating the Vivado_init.tcl file and adding "enable_beta_device*" in it.
enable_beta_device* in the tcl console is not the solution as it does not apply to all vivado processes (it seems like it anyway).
Sébastien
--Sebastien
Note that I can't select the ES version of a ZCU7EV. Only "EG".
It is not available in vivado 2018.1...
So I think that's the reason why the board is not seen.
Is there a way to add these devices?
--Sebastien
Hi @sebo,
1. Make sure you have installed the ES devices during the installation of vivado (you can change this from the Xilinx information center)
2.You need a license for the ES devices, make sure you are pointing to it
3. Make sure you do "enable_beta_device *" when starting vivado or in the vivado_init.tcl file.
Florent
Hello Florent,
I've checked all that.
I was able to start (on linux) a project for that board. however, the selected part was not found.
That's a problem that I don't find on windows.
Sébastein.
--Sebastien
@sebo
You can store the files in a location and use the following command in tcl console :
set_param board.repoPaths <location to ZCU106 Board files>
It will be much better if you could place this command in the Vivado_init.tcl file in the Xilinx/Vivado/<version>/scripts folder as you can see the board on startup.
Nupur
Hi Sebastien @sebo,
Try to use enable_beta_devices* in the vivado_init.tcl file not directly from the tcl console.
Florent
Sébastien
--Sebastien
